Question on Sparkfun Eagle Library
Hey guys, so for a PCB design I did, I used the Sparkfun-Connectors.lbr for some breakout pin headers I wanted to add. Problem is, I used the following header and I cannot find the actual physical piece that corresponds to it!
https://drive.google.com/thumbnail?id=0 … 1008-h1197
Let me know if the link doesn’t work, its the 1X05-1MM SMD connector. Anyone know where I can find it? Specifically the SMD version. I’ve already fabbed PCBs so there’s no turning back now. The PRTs listed for it on Sparkfun aren’t small enough, because the spacing is smaller than typical .1" headers.
Much appreciated!
