question related to Reset pin of AVR
How many ways of interfacing AVR reset pin are there? can you connect Reset pin directly to ground via a switch? Thanks
See the data sheet!
I usually use a 4k75 pullup and a 100nf to ground. You can add a button to ground too if you want, or just use a jumper on the ISP connector.
/mike
