I’m designing something using a ATmega128RFA’s built-in 2.4 GHz transceiver, based off the example application circuit provided in the datasheet, and also based on the SparkFun ATmega128RFA development board.
For my PCB layout, I can guarantee that the trace length of the differential RF output of the transceiver will be equal if I swap the inputs to the balun. In my mind, this shouldn’t break the circuit functionally, correct?
Here’s the two schematics to illustrate what I did differently
