This is an issue I am having too.
I have an Arduino Nano Every connected to a Qwiic OpenLog and a Qwiic alphanumeric display.
It seems to me like the SparkFun libraries are not 100% compatible with the Arduino Nano Every (megaAVR).
When compiling the code, the compiler throws a number of messages:
In file included from C:\Users\currentUser\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\src/SparkFun_Alphanumeric_Display.h:28:0,
from C:\Users\currentUser\Documents\Arduino\libraries\SparkFun_Qwiic_Alphanumeric_Display_Arduino_Library\src\SparkFun_Alphanumeric_Display.cpp:32:
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function ‘bool HT16K33::readRAM(uint8_t, uint8_t, uint8_t*, uint8_t)’:
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h:63:12: note: candidate 1: size_t TwoWire::requestFrom(int, int)
size_t requestFrom(int, int);
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h:61:12: note: candidate 2: virtual size_t TwoWire::requestFrom(uint8_t, size_t)
size_t requestFrom(uint8_t, size_t);
In file included from C:\Users\currentUser\Documents\Arduino\libraries\SparkFun_Qwiic_OpenLog\src\SparkFun_Qwiic_OpenLog_Arduino_Library.h:36:0,
from C:\Users\currentUser\Documents\Arduino\libraries\SparkFun_Qwiic_OpenLog\src\SparkFun_Qwiic_OpenLog_Arduino_Library.cpp:28:
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function ‘arduino::String OpenLog::getVersion()’:
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function ‘uint8_t OpenLog::getStatus()’:
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function ‘int32_t OpenLog::size(arduino::String)’:
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function ‘void OpenLog::read(uint8_t*, uint16_t, arduino::String)’:
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function ‘arduino::String OpenLog::getNextDirectoryItem()’:
C:\Users\currentUser\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function ‘uint32_t OpenLog::remove(arduino::String, boolean)’:
Googling these messages suggests that there’s some ambiguity in which function the compiler is supposed to call.
