Qwiic Button and LED Stick- Prevent Button Hold down event
For my project I have a Qwiic Button and Qwiip LED stick. I want to be able to cycle the LED stick from Green, Yellow and Red by pressing the button . As a total newbie to Arduino’s I am running into an issue with the button being held down and cycling through each color in a few miliseconds.
here is my code I’m open to any suggestions
QwiicButton button;
LED LEDStick; //Create an object of the LED class
int countPush = 1;// count the number of pushes
int lastcountPush;
unsigned long debounceDelay = 250; // ignore any additional button presses after the first press for this time
uint16_t brightness = 250; //The maximum brightness of the pulsing LED. Can be between 0 (min) and 255 (max)
uint16_t cycleTime = 1000; //The total time for the pulse to take. Set to a bigger number for a slower pulse, or a smaller number for a faster pulse
uint16_t offTime = 200; //The total time to stay off between pulses. Set to 0 to be pulsing continuously.
void setup() {
Wire.begin();
//Start up communication with the LED Stick
if (LEDStick.begin() == false) {
Serial.println(“Qwiic LED Stick failed to begin. Please check wiring and try again!”);
while (1);
if (button.begin() == false) {
Serial.println(“Device did not acknowledge! Freezing.”);
while (1);
Serial.println(“Button acknowledged.”);
Serial.println(“Qwiic LED Stick ready!”);
void loop() {
if (button.timeSinceLastPress() > debounceDelay && button.isPressed() == true) // If the time from the last push is less than debounce delay of 250ms and the button is pushed add one to the pushCount
Serial.println(“The button is pressed!”);
Serial.print(button.timeSinceLastPress()/1000.0); // print the time since the button was last pressed
button.LEDon(brightness);
countPush++; // Count the number of times the button has been pushed
Serial.println(countPush);
delay(100);
else
Serial.println(“BUTTON IS NOT PRESSED”);
switch(countPush){ // use the countPush to cycle between Green, Yellow and Red
case 1: // Turn the LED to Green for countPush 1
LEDStick.setLEDColor(00, 10, 00);
Serial.println(“green”);
delay(100);
break;
case 2: // Turn the LED to Yellow for countPush 2
LEDStick.setLEDColor(10, 10, 00);
Serial.println(“yellow”);
delay(100);
break;
case 3: // Turn the LED to Red for countPush 3
LEDStick.setLEDColor(10, 00, 00);
Serial.println(“red”);
delay(100);
break;
default: // If the pushcount is higher than 3 change the pushCount to 1 so they cycle start over
countPush = 1;
Serial.println(“Default”);
delay(100);
break;
You may need to alter the debounce time, or the cycle time to better match your use-case
