I’m using the SparkFun MLX90640 with a Jetson Nano through the Qwiic cable. The wiring is correct (3.3V, GND, SDA, SCL).
The first time I connected the sensor, i2cdetect -y 1 showed the address 0x33 once. But after that, the address disappeared completely and never came back.
I tried again with the same Qwiic cable and correct pins, but now the MLX90640 is not detected at all.
Could this be a problem with the Qwiic cable, or is it possible that the sensor board was damaged? What is the recommended way to troubleshoot this situation?
Thank you.
