My Arduino Mega cannot connect to my QWIIC micropressure sensor. All my other QWIIC sensors are found.
When I run an address scanner with only the micropressure sensor hooked up it does not find an address. I believe the default address is 0x18.
Any ideas?
Did you try hooking it up by itself? Share a photo of the wiring/set-up
Like I sead above only the micropressure sensor is hooked up and it will not see it. If I try another sensor like the BMP280 it finds it. Do I have a broken sensor?
I think so - Was it purchased from us? If so head over to www.sparkfun.com/returns Contact vendor if purchased elsewhere and we’ll get ya squared away
