I have a quick question about this sensor, will it work with the BASYS3 FPGA Board and Vivado Design Suite? I wasn’t sure if it would because of the Qwiic connector to the board. Thank you in advance! I need to run 4 distance sensors for collision avoidance and proximity detection on a rover and thought this specific sensor might be my best option, if anyone thinks something is better, let me know!
The qwiic connector is essentially a branch off of the designated I2c pins on the board. You will be able to interface with the 0.1" spaced pins on the edge of the board to access this interface instead of the connector if you like.
