qwiic mux
How do you read from multiple grid eye sensors with the same address (eg 0x68) from an Arduino Uno using the Qwiic MUX?
The Qwiic MUX is just like a rotary selector switch except that you send it a command to change channels. Your code will need to select a channel, communicate with sensor on that channel and then switch to another channel before talking to the new sensor.
We can’t help with code but check the [example in the hookup guide for how things should look.](Qwiic MUX Hookup Guide - SparkFun Learn)
