random signals
Hi there
new to the forum, have read some posts with similar problems but not quite the same. Am using RF24G radio chip. I’ve used very simple code to test the radio chip. Basically just receiving noise. it seems to work, the DR1 pin is being pulled up and down. (Its incredible how much information matches my preamble and address!)
But heres my problem, I’m getting 8 bits of random info and showing them on LED’s. Only the pattern never changes. I am receiving continously and would expect the pattern to change. Its not possible for the air to be saturated with the same random pattern is it?? (That sounds crazy)
Anyway anyone with a similar problem, your experience would be a great help
The thread ‘TRW-24G TX/RX Module’ may be of use to you.
Try using a long address (40 bits) and 16-bit CRC.
