I am currently working on a project that requires me to do some wireless do communication. One of the nodes at static and the other nodes is moving at about 60mph-70mph. I need to be able to transmit data about 10-50 bits of data. The range is about 500 meters. Can someone recommend a wireless module I can use to do this.
A pair of mini-wireless boards with Arduino mega32 aboard and a 100mW data transceiver. Low cost. There are more costly, more elegant ways, but this will likely work, if there are not a lot of obstructions in the path.
Consider using this software, then the app becomes just a few lines of code mod to on of the examples
stevech:
jassminsmithh:
I would agree over the XBee Series 1 Pro as I have heard a lot about this and surely thinks that this will fulfill all your requirements.
I did consider the XBee Pros, but I wanted something lower in cost, in the long run and additionally the Pros I tested dint do farther than 100 meters even after using the Dipole antennas, and I dint want to use antennas bigger than that.
Anyways thanks for the suggestion, will continue looking for options.
jassminsmithh:
