I would like to have a recommendation for an Display. I have the following requirements.
Easy to program, qwiic connection with i2C
Display size 1,5-3 inch … only 4 lines are required (with each line about 10-30 numbers/letters)
Update frequency in range of minutes
Low energy consumption may be e-paper in continuous mode or any other display that could be switched off (or go into sleep mode) via i2C command.
Is there a selection guide available that helps to choose the right one?
Thank you!
Best regards, Constantin
