Red Board Artemis OLA and F9 GNSS
I could use a little help.
I have a redboard Artemis OLA and Ublox F9 Sparkfun Board. They are connected via qwic.
I have reviewed the OpenLog_Artemis_GNSS_Logger repository. I installed OpenLog_Artemis-V10-v19.bin
I am trying to compile and load OpenLog_Artemis_GNSS_Logging.ino with the IDE. I get the following error when I try to compile.
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\storeData.ino:368:23: note: suggested alternative: ‘RTC’
myRTC.setTime(UBXbuffer[22], UBXbuffer[23], UBXbuffer[24], centis, UBXbuffer[21], UBXbuffer[20], (rtcYear - 2000)); //Set the RTC
RTC
Multiple libraries were found for “SdFat.h”
Used: C:\Users\User\Documents\Arduino\libraries\SdFat
Not used: C:\Users\User\Documents\Arduino\libraries\SdFat_-_Adafruit_Fork
exit status 1
no matching function for call to ‘arduino::MbedI2C::MbedI2C(int)’
I have the board set to Red Board Artemis ATP
I am using the recommended Sparkfun Variable Loader.
I read installing the Apollo board installs all of the libraries but I don’t know if I have all of the required libraries installed.
Any help is kindly appreciated.
Thank you
Hi David,
OpenLog Artemis currently only compiles under version 1.2.1 of the Apollo3 boards. We haven’t been brave enough to upgrade to v2 - yet…
Hope all is well. Let me know if you need any more help,
Hello Paul,
Thanks for the blazingly fast reply. I’ll load 1.2.1 and let you know how it goes.
Hope you are well,
David
Paul,
I installed 1.2.1. I got the following error when compiled the code:
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "SparkFun RedBoard Artemis ATP, 115200, SparkFun Variable Loader (Recommended)"
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino: In function 'bool beginSensors()':
Sensors:87:37: error: 'UBLOX_CFG_I2COUTPROT_UBX' was not declared in this scope
       gpsSensor_ublox.newCfgValset8(UBLOX_CFG_I2COUTPROT_UBX, VAL_LAYER_RAM | VAL_LAYER_BBR); // CFG-I2COUTPROT-UBX : Enable UBX output on the I2C port (in RAM and BBR)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:87:37: note: suggested alternative: 'VAL_ID_I2COUTPROT_UBX'
Sensors:88:37: error: 'UBLOX_CFG_I2COUTPROT_NMEA' was not declared in this scope
       gpsSensor_ublox.addCfgValset8(UBLOX_CFG_I2COUTPROT_NMEA, 0); // CFG-I2COUTPROT-NMEA : Disable NMEA output on the I2C port
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:88:37: note: suggested alternative: 'VAL_ID_I2COUTPROT_NMEA'
Sensors:91:39: error: 'UBLOX_CFG_I2COUTPROT_RTCM3X' was not declared in this scope
         gpsSensor_ublox.addCfgValset8(UBLOX_CFG_I2COUTPROT_RTCM3X, 0); // CFG-I2COUTPROT-RTCM3X : Disable RTCM3 output on the I2C port (Precision modules only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:91:39: note: suggested alternative: 'VAL_ID_I2COUTPROT_RTCM3'
Sensors:93:56: error: 'UBLOX_CFG_INFMSG_UBX_I2C' was not declared in this scope
       uint8_t success = gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_INFMSG_UBX_I2C, 0, 2100); // CFG-INFMSG-UBX_I2C : Disable UBX INFo messages on the I2C port (maxWait 2100ms)
Sensors:115:43: error: 'UBLOX_CFG_USB_ENABLED' was not declared in this scope
         success = gpsSensor_ublox.setVal8(UBLOX_CFG_USB_ENABLED, 0, VAL_LAYER_RAM, 1100); // CFG-USB-ENABLED (in RAM only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:115:43: note: suggested alternative: 'UBX_CFG_USB'
                                           UBX_CFG_USB
Sensors:135:43: error: 'UBLOX_CFG_UART1_ENABLED' was not declared in this scope
         success = gpsSensor_ublox.setVal8(UBLOX_CFG_UART1_ENABLED, 0, VAL_LAYER_RAM, 1100); // CFG-UART1-ENABLED (in RAM only)
Sensors:155:43: error: 'UBLOX_CFG_UART2_ENABLED' was not declared in this scope
         success = gpsSensor_ublox.setVal8(UBLOX_CFG_UART2_ENABLED, 0, VAL_LAYER_RAM, 1100); // CFG-UART2-ENABLED (in RAM only)
Sensors:175:43: error: 'UBLOX_CFG_SPI_ENABLED' was not declared in this scope
         success = gpsSensor_ublox.setVal8(UBLOX_CFG_SPI_ENABLED, 0, VAL_LAYER_RAM, 1100); // CFG-SPI-ENABLED (in RAM only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:175:43: note: suggested alternative: 'UBX_CFG_GEOFENCE'
                                           UBX_CFG_GEOFENCE
Sensors:262:38: error: 'UBLOX_CFG_RATE_MEAS' was not declared in this scope
       gpsSensor_ublox.newCfgValset16(UBLOX_CFG_RATE_MEAS, measRate, VAL_LAYER_RAM); // CFG-RATE-MEAS : Configure measurement period (in RAM only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:262:38: note: suggested alternative: 'UBX_CFG_RATE'
                                      UBX_CFG_RATE
Sensors:263:49: error: 'UBLOX_CFG_RATE_NAV' was not declared in this scope
       success = gpsSensor_ublox.sendCfgValset16(UBLOX_CFG_RATE_NAV, 1, 2100); // CFG-RATE-NAV : 1 measurement per navigation solution (maxWait 2100ms)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:263:49: note: suggested alternative: 'UBX_CFG_RATE'
                                                 UBX_CFG_RATE
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino: In function 'uint8_t disableMessages(uint16_t)':
Sensors:464:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_I2C, 0, VAL_LAYER_RAM); // CFG-MSGOUT-UBX_NAV_CLOCK_I2C (in RAM only)
Sensors:465:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_ATT_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_ATT_I2C, 0); // CFG-MSGOUT-UBX_NAV_ATT_I2C
Sensors:466:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_DOP_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_DOP_I2C, 0); // CFG-MSGOUT-UBX_NAV_DOP_I2C
Sensors:467:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_ODO_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_ODO_I2C, 0); // CFG-MSGOUT-UBX_NAV_ODO_I2C
Sensors:468:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_POSECEF_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_POSECEF_I2C, 0); // CFG-MSGOUT-UBX_NAV_POSECEF_I2C
Sensors:469:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_POSLLH_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_POSLLH_I2C, 0); // CFG-MSGOUT-UBX_NAV_POSLLH_I2C
Sensors:470:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_PVT_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_PVT_I2C, 0); // CFG-MSGOUT-UBX_NAV_PVT_I2C
Sensors:471:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_STATUS_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_STATUS_I2C, 0); // CFG-MSGOUT-UBX_NAV_STATUS_I2C
Sensors:472:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_TIMEUTC_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_TIMEUTC_I2C, 0); // CFG-MSGOUT-UBX_NAV_TIMEUTC_I2C
Sensors:473:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_VELECEF_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_VELECEF_I2C, 0); // CFG-MSGOUT-UBX_NAV_VELECEF_I2C
Sensors:474:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_VELNED_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_VELNED_I2C, 0); // CFG-MSGOUT-UBX_NAV_VELNED_I2C
Sensors:475:45: error: 'UBLOX_CFG_MSGOUT_UBX_RXM_SFRBX_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_RXM_SFRBX_I2C, 0); // CFG-MSGOUT-UBX_RXM_SFRBX_I2C
Sensors:476:46: error: 'UBLOX_CFG_MSGOUT_UBX_TIM_TM2_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_MSGOUT_UBX_TIM_TM2_I2C, 0, maxWait); // CFG-MSGOUT-UBX_TIM_TM2_I2C
Sensors:479:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSECEF_I2C' was not declared in this scope
   success2 &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSECEF_I2C, 0, VAL_LAYER_RAM); // CFG-MSGOUT-UBX_NAV_HPPOSECEF_I2C
Sensors:480:46: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSLLH_I2C' was not declared in this scope
   success2 &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSLLH_I2C, 0, maxWait); // CFG-MSGOUT-UBX_NAV_HPPOSLLH_I2C
Sensors:482:46: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_RELPOSNED_I2C' was not declared in this scope
   uint8_t success3 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_NAV_RELPOSNED_I2C, 0, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_NAV_RELPOSNED_I2C
Sensors:484:46: error: 'UBLOX_CFG_MSGOUT_UBX_RXM_RAWX_I2C' was not declared in this scope
   uint8_t success4 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_RXM_RAWX_I2C, 0, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_RXM_RAWX_I2C
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino: In function 'uint8_t enableMessages(uint16_t)':
Sensors:510:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_CLOCK_I2C, settings.sensor_uBlox.logUBXNAVCLOCK, VAL_LAYER_RAM); // CFG-MSGOUT-UBX_NAV_CLOCK_I2C (in RAM only)
Sensors:511:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_DOP_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_DOP_I2C, settings.sensor_uBlox.logUBXNAVDOP); // CFG-MSGOUT-UBX_NAV_DOP_I2C
Sensors:512:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_ODO_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_ODO_I2C, settings.sensor_uBlox.logUBXNAVODO); // CFG-MSGOUT-UBX_NAV_ODO_I2C
Sensors:513:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_POSECEF_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_POSECEF_I2C, settings.sensor_uBlox.logUBXNAVPOSECEF); // CFG-MSGOUT-UBX_NAV_POSECEF_I2C
Sensors:514:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_POSLLH_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_POSLLH_I2C, settings.sensor_uBlox.logUBXNAVPOSLLH); // CFG-MSGOUT-UBX_NAV_POSLLH_I2C
Sensors:515:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_PVT_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_PVT_I2C, settings.sensor_uBlox.logUBXNAVPVT); // CFG-MSGOUT-UBX_NAV_PVT_I2C
Sensors:516:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_STATUS_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_STATUS_I2C, settings.sensor_uBlox.logUBXNAVSTATUS); // CFG-MSGOUT-UBX_NAV_STATUS_I2C
Sensors:517:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_TIMEUTC_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_TIMEUTC_I2C, settings.sensor_uBlox.logUBXNAVTIMEUTC); // CFG-MSGOUT-UBX_NAV_TIMEUTC_I2C
Sensors:518:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_VELECEF_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_VELECEF_I2C, settings.sensor_uBlox.logUBXNAVVELECEF); // CFG-MSGOUT-UBX_NAV_VELECEF_I2C
Sensors:519:45: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_VELNED_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_VELNED_I2C, settings.sensor_uBlox.logUBXNAVVELNED); // CFG-MSGOUT-UBX_NAV_VELNED_I2C
Sensors:520:45: error: 'UBLOX_CFG_MSGOUT_UBX_RXM_SFRBX_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_MSGOUT_UBX_RXM_SFRBX_I2C, settings.sensor_uBlox.logUBXRXMSFRBX); // CFG-MSGOUT-UBX_RXM_SFRBX_I2C
Sensors:521:46: error: 'UBLOX_CFG_MSGOUT_UBX_TIM_TM2_I2C' was not declared in this scope
   success1 &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_MSGOUT_UBX_TIM_TM2_I2C, settings.sensor_uBlox.logUBXTIMTM2, maxWait); // CFG-MSGOUT-UBX_TIM_TM2_I2C
Sensors:526:47: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSECEF_I2C' was not declared in this scope
     success2 &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSECEF_I2C, settings.sensor_uBlox.logUBXNAVHPPOSECEF, VAL_LAYER_RAM); // CFG-MSGOUT-UBX_NAV_HPPOSECEF_I2C
Sensors:527:48: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSLLH_I2C' was not declared in this scope
     success2 &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_MSGOUT_UBX_NAV_HPPOSLLH_I2C, settings.sensor_uBlox.logUBXNAVHPPOSLLH, maxWait); // CFG-MSGOUT-UBX_NAV_HPPOSLLH_I2C
Sensors:533:40: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_RELPOSNED_I2C' was not declared in this scope
     success3 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_NAV_RELPOSNED_I2C, settings.sensor_uBlox.logUBXNAVRELPOSNED, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_NAV_RELPOSNED_I2C
Sensors:539:40: error: 'UBLOX_CFG_MSGOUT_UBX_RXM_RAWX_I2C' was not declared in this scope
     success4 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_RXM_RAWX_I2C, settings.sensor_uBlox.logUBXRXMRAWX, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_RXM_RAWX_I2C
Sensors:545:40: error: 'UBLOX_CFG_MSGOUT_UBX_NAV_ATT_I2C' was not declared in this scope
     success5 = gpsSensor_ublox.setVal8(UBLOX_CFG_MSGOUT_UBX_NAV_ATT_I2C, settings.sensor_uBlox.logUBXNAVATT, VAL_LAYER_RAM, maxWait); // CFG-MSGOUT-UBX_NAV_ATT_I2C
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino: In function 'uint8_t enableConstellations(uint16_t)':
Sensors:570:44: error: 'UBLOX_CFG_SIGNAL_GPS_ENA' was not declared in this scope
   success &= gpsSensor_ublox.newCfgValset8(UBLOX_CFG_SIGNAL_GPS_ENA, settings.sensor_uBlox.enableGPS, VAL_LAYER_RAM);  //CFG-SIGNAL-GPS_ENA   : Enable GPS (in RAM only)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:570:44: note: suggested alternative: 'UBX_MGA_GPS_EPH'
                                            UBX_MGA_GPS_EPH
Sensors:571:44: error: 'UBLOX_CFG_SIGNAL_GLO_ENA' was not declared in this scope
   success &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_SIGNAL_GLO_ENA, settings.sensor_uBlox.enableGLO);                 //CFG-SIGNAL-GLO_ENA   : Enable GLONASS
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:571:44: note: suggested alternative: 'UBX_MGA_GLO_EPH'
                                            UBX_MGA_GLO_EPH
Sensors:572:44: error: 'UBLOX_CFG_SIGNAL_GAL_ENA' was not declared in this scope
   success &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_SIGNAL_GAL_ENA, settings.sensor_uBlox.enableGAL);                 //CFG-SIGNAL-GAL_ENA   : Enable Galileo
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:572:44: note: suggested alternative: 'UBX_MGA_GAL_EPH'
                                            UBX_MGA_GAL_EPH
Sensors:573:44: error: 'UBLOX_CFG_SIGNAL_BDS_ENA' was not declared in this scope
   success &= gpsSensor_ublox.addCfgValset8(UBLOX_CFG_SIGNAL_BDS_ENA, settings.sensor_uBlox.enableBDS);                 //CFG-SIGNAL-BDS_ENA   : Enable BeiDou
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:573:44: note: suggested alternative: 'UBX_MGA_BDS_EPH'
                                            UBX_MGA_BDS_EPH
Sensors:574:45: error: 'UBLOX_CFG_SIGNAL_QZSS_ENA' was not declared in this scope
   success &= gpsSensor_ublox.sendCfgValset8(UBLOX_CFG_SIGNAL_QZSS_ENA, settings.sensor_uBlox.enableQZSS, maxWait);     //CFG-SIGNAL-QZSS_ENA  : Enable QZSS (maxWait 2100 ms)
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\Sensors.ino:574:45: note: suggested alternative: 'UBX_MGA_QZSS_EPH'
                                             UBX_MGA_QZSS_EPH
C:\Users\User\Desktop\F9 Logger\Artemis Logger\OpenLog_Artemis_GNSS_Logger-master\Firmware\OpenLog_Artemis_GNSS_Logging\storeData.ino: In function 'bool storeData()':
storeData:183:60: error: 'class SFE_UBLOX_GPS' has no member named 'getI2CTransactionSize'
       uint16_t maxTransaction = (uint16_t)(gpsSensor_ublox.getI2CTransactionSize());
Multiple libraries were found for "SdFat.h"
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Hi David,
OLA now uses the shiny new version of the u-blox GNSS library. Click on the link in line 213 in OpenLog_Artemis.ino to install it:
https://github.com/sparkfun/OpenLog_Art … s.ino#L213
You can have the old and new versions installed at the same time.
Old:
https://github.com/sparkfun/SparkFun_Ub … no_Library
New and shiny:
https://github.com/sparkfun/SparkFun_u- … no_Library
BW,
Sorry… Cancel that…
You’re trying to compile the “GNSS Logger” version of the OLA code…
That one still uses the old version…
https://github.com/sparkfun/OpenLog_Art … g.ino#L175
Let me know if you hit more problems. I haven’t built that version for a while and, really, it could do with being upgraded to the new u-blox library.
There are some examples here that might do what you are looking for?
https://github.com/sparkfun/SparkFun_u- … ta_Logging
Hey Paul,
I have both Arduino U-blox Libraries installed. And I am using DataLoggingExample3_RXM, SFRBX_and_RAWX.
When I compile I get CS was not declared in this scope.
Line 60.
Sorry I require so much assistance.
Dave
Hi Dave,
Not a problem.
The data logging examples are written for the MicroMod Artemis and MicroMod Data Logging Carrier Board.
You need to change CS (Chip Select) to match the pin on your OpenLog Artemis.
On the OLA, the CS pin is 23 or 10 depending on whether you have a Red V10 board or the older black X04 board (see pin definitions below).
Now then, thinking about this a bit more, you are about to run into more problems because on OLA you will also need to enable power for the Qwiic bus (so the GNSS has power), enable power for the SD card and enable the SPI CIPO pull-up.
The extra bits of code you need to copy and paste are:
https://github.com/sparkfun/OpenLog_Art … #L106-L138
https://github.com/sparkfun/OpenLog_Art … #L764-L766
https://github.com/sparkfun/OpenLog_Art … #L819-L832
https://github.com/sparkfun/OpenLog_Art … #L516-L546
I have an outstanding action to write a proper data logging example for OLA using the new u-blox GNSS library ( https://github.com/sparkfun/OpenLog_Artemis/issues/73 ) but I haven’t got around to it yet… Sorry about that! I can’t look at it right now, but I will try and get to it in a few days.
Oh boy, sorry, there’s another complication… On OLA the I2C bus is called “qwiic” not the usual “Wire”.
So, there is this to add too:
https://github.com/sparkfun/OpenLog_Art … #L150-L153
When you .begin the GNSS, you then need to call myGNSS.begin(qwiic) not myGNSS.begin()
I really need to work on that dedicated example…
Paul,
I went back to OpenLog_Artemis_GNSS_Logging.ino with Apollo 1.2.1.
I also deleted an Adafruit_Fork for the SDFat and an old U_blox Library that may have created some conflicts. It compiled, uploaded and it’s logging data as I type.
I really like the menu option through the serial terminal. That is really slick. Nice work!
I think I am logging everything I need to post process with RTKLIB. I am logging a 1hz and while probably not necessary I disabled outputs to SPI, UART1 and UART2.
Thanks for the great work and amazing customer support.
David
Thanks David - glad that’s working for you,
I will try and get that dedicated example for OLA done soon - for my own piece of mind if nothing else!
Paul,
I am pleased to report the ubx file processed well with OPUS and RTKLIB. Everything is working well.
Thanks for your help, patience and a cool product.
Dave
Hi Dave,
Thanks for letting me know.
You are very welcome - as always,
