I hooked up a RFM69HCW to the SparkFun Pro nRF52840 Mini and it kept dropping the Bluetooth connection whenever I transmitted. I reduced the power level and it started work, which leads me to believe that I was drawing too much current through the regulator and it was resetting. I couldn’t find which regulator was used in the schematic, so if you could point me in the right direction that would be great.
I just looked into this a bit more and realizd that the max current for the AP2112K is 600ma, and the max current for the RFM69 is only 130ma. Does that mean the MDBT50Q is drawing close to 500ma, or am I missing something?
No problem. I order one of those USB meters to see if I can measure what it’s drawing. Trying to dig through the datasheet to figure out what the BLE and processor was drawing wasn’t worth it to me given that slightly reducing the power is fine for my application.
