$16/100 pcs for 8bit micro @50Mhz? who will use these when there are ARMs at 1/3 of this price with better capabilities?
Best regards
Tsvetan
Hi Tsvetan,
I see your point. The SUPER-H series is (from my understanding) a 32 bit processor solution. It looks like it may have better support with the GNU toolchain.
I have purchased quite a few different development platforms now (Olimex via Sparkfun) trying to find the ultimate solution. Microchip has wayyy to many problems with their hardware for my tastes (i.e. Errata and compiler issues). Not trying to start a war here, but I am done with them. Amazingly people must still buy them.
AVR ATMega128 has been very good to me so far, but I am looking for more powerful solution right now. The ARM core is definitely the main candidate on my list, but I’m not convinced that the debugging tools are completely polished yet. The OpenOCD project / ARM-USB-OCD combo seems to still need some work. It isn’t working too well for me anyway. I’m trying to find a good solution for development with Linux as the host platform and have the development tools “just work as expected”.
I think there would be others that would think along the same lines. I know I would be willing to pay the extra for system cost if the development tools are rock solid (mature) on Linux host platform… I am a newcomer to the 32 bit microcontroller arena, so I might be way off. Suggestions are welcome.
It seems to be quite similar to, say, an AVR, but with one very nice addition: CAN. It comes in a 9mmx9mm leaded package, while the CAN AVRs come in 16mmx16mm leaded packages and 9mmx9mm QFNs. Neither of those will work for my application as I need a chip that can fit on a 15mm wide board (3mm on each side of the QFN is not enough space to route traces around, and you can’t run traces on the top layer beneath the QFN as it has a ground pad).
So, do you know if that compiler will support the R8C/23? Also, how does one program one of these chips?
leon_heller:
The Rowley CrossWorks ARM debugger is very good, and their tools are available for Linux.
Leon
Thanks. I will check that out. I looked at their compiler once, but I think I prefer GNU GCC environment. I had not thought of just using their debugger solution though… That might be a great combo.?
