I am using an olimex arm-usb-ocd-h connected to a Digilent Nexys2 board to program the fpga and then access the USER jtag registers using openocd.
Is there any way to have the svf player display the data returned with each jtag access? I can use the expected value set wrong to get and error
message with the incorrect bits but that only works once on the first error. Can you dump out the Wrote,Read and expected values for each access?
John Eaton
