RF-KLP-315 servo control
i would like to use the RF-KLP-315 to remotely control 2 servos from my pc.
is it possible to connect the transmitter directly to serial/parallel port?
and the receiver to servo.
will i need to use filtering in the receiver side such as 555 timer (servo is square wave) ?
will in need a pic/avr in the transmitter side? if so can i have more details?
will this do it say i connect this http://www.pololu.com/products/pololu/0207/ to the pc and instead of conecting the servos conect the signal to the transmitter
any other info about what im up against will be great
thx,
-atntias
That Pololu product says it has an RS232 (serial data) compatible interface to a PC. With the right connector (DB9), it should just plug in.
If you want to go wireless, IMO, the easiest way would be with a pair of Maxstream XBee modules at $19ea or the $35 XBeePro. No software - they just extend a serial port wirelessly to any number of mobile nodes.
