Hi
I’m trying incorporate wireless control into my design rather than have hard wired components due to cosmetics and the installation
I have no knowledge whatsoever of wireless apparatus and components but thought if it could be done wireless then it would be the perfect setup. So I’m asking for your help and advice please
I have a line diagram pdf but dont know how to upload it
I’m trying to design an aftermarket system for in ground swimming pools that will auto drain the pool when the level of the pool water reaches a certain point by energizing an electric valve actuator and intern opening the valve to drain the pool. Then when the water drops to an idea level closes the drain valve. It also has a failsafe to shut off the equipment if the drain valve stayed open or let’s say a burst in the pipe work or equipment
Initially I went down the thought of hard wiring but really I don’t think that would be good from both installation and cosmetics .
So today I thought would it be possible to use wireless transmitters and receivers but that’s where in totally lost.
If this is not in your sphere then maybe you could direct me in the correct direction as to where I could find help
My main question is could this be achieved?
Chris
