Does anyone know of strings of these lights with other diviner IC options? I think there was some with a TI driver around but I can not remember the P/N of the IC.
https://dlnmh9ip6v2uc.cloudfront.net//i … 20-01a.jpgDiviner IC options ??Chupa:
From your post you know of 2801 vs 2811; are you asking about other individual control “concepts” implemented in a string of LEDs ?
Adafruit sells some strings based on the LDP8803/8806 IC and there’s some Arduino libraries for it.
http://www.adafruit.com/products/306
There’s also a TM1803 IC that I know nothing about. Looks like a W2811 clone ?
http://www.users.on.net/~avd/acl/TM1803.pdf
Adafruit also has some strips using the HL1606 IC
Mee_n_Mac:
Does anyone know of strings of these lights with other diviner IC options?From your post you know of 2801 vs 2811; are you asking about other individual control “concepts” implemented in a string of LEDs ?
My fault. I meant driver!
I am just looking for other ICs that are beuing used to make the “Christmas lights” style individuality addressable LEDs strings.
Mee_n_Mac:
Adafruit sells some strings based on the LDP8803/8806 IC and there’s some Arduino libraries for it.http://www.adafruit.com/products/306
So far its looks like these are the options divided into 1 wire or 2 wire categories:
[TM1803 (5V 800Kbps)
[WS2811 (5V 800Kbps)
Two wire
[LPD6803 (5V 15MHz)
[WS2801 (5V 25MHz)
[LPD8803 (5V 20MHz)
[LPD8806 (same as above with 6 chan)
[HL1606 (w/ latch)
[/list]
I still can not find that TI chip that I stumbled across the other day… I guess its not used very much.](http://www.adafruit.com/datasheets/HL1606E.pdf)](https://solarbotics.com/download.php?file=1889)](https://solarbotics.com/download.php?file=1889)](http://www.sparkfun.com/datasheets/Components/LED/WS2801.pdf)](http://www.adafruit.com/datasheets/LPD6803.pdf)](http://www.adafruit.com/datasheets/WS2811.pdf)](深圳市天微电子股份有限公司-原厂)
Here’s a link that has a fairly good table in it.
