I have a SparkFun SAM-M10Q breakout board that I’ve been having some trouble with. I am very new to ublox modules and gnss in general so please bear with me. I’ve connected the receiver to ucenter and for whatever reason am having a very hard time acquiring a fix. In its default configuration, it does not seem to acquire any fix at all, or even find any satellites. I’ve found that if I increase the baudrate to 57600, set the measurement rate to 5Hz, and increase the output rate of the UBX PVT messages, I can eventually find satellites and acquire a fix, but it takes anywhere between 10-20 minutes and will lose the fix after around 1-5 seconds, and then take anywhere from 1-5 minutes to acquire another fix. A few minutes ago with this configuration it was able to discover ~30 satellites at once and yet it did not appear to be receiving a signal from a single one of them over a period of 20 minutes. This was all done outside with clear view of the sky on a partly cloudy day. From what I understand this module should be capable of acquiring a fix in less than a minute from cold start. If anyone could help me troubleshoot these issues it would be very much appreciated
