SCD30 - how to know if only one sensor is not working ?
I recently posted an issue on the repository SparkFun_SCD30_Arduino_Library :
https://github.com/sparkfun/SparkFun_SC … /issues/28
and I was suggested to ask my question here.
Considering I am working with only 1 scd30 chip
https://www.sparkfun.com/products/15112
that has 3 different sensors in it (co2, humidity and temperature).
Is there a way for me to know if the co2 sensor stopped working, while the other 2 sensors are stil working perfectly.
Can I know it using the SparkFun_SCD30_Arduino_Library ?
Thank you
There is NO instruction on the SCD30 where one can ask for the sensor status (working or not). All sensor communication is handled by the on-board STML032U6. The instructions that can be used are defined in https://www.sensirion.com/fileadmin/use … iption.pdf
