SeeedStudio XBEE 2.0 shield with Due
Hi -
I want to use an XBEE 2.0 shield from SeeedStudio with my Arduino Due. The shield does level shifting, so I am assuming I need to either bypass the level shifting or shift the levels again myself on the TX/RX lines that go from the Due to the shield. Is that a correct assumption? Does anyone have experience with this shield?
I am thinking it will only be an issue on the Due RX line, assuming the shield converts its TX line to 5V.
Any advice on the simplest way to use this shield with Due is appreciated.
Dennis
