I’ve got the 0.1.0 release of OpenOCD and I’m seeing a segmentation fault after a couple steps with arm-elf-gdb. I wasn’t able to gather any useful information yet, when I run openocd in gdb it can’t find standard config files (some kind of environment problem). Anyone seen this before?
$ openocd -f ~/dev/ocd/openocd.cfg
Open On-Chip Debugger 0.1.0 (2009-01-22-11:22) Release
BUGS? Read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS
$URL: https://kc8apf@svn.berlios.de/svnroot/repos/openocd/tags/openocd-0.1.0/src/openocd.c $
Info : JTAG tap: sam7x256.cpu tap/device found: 0x3f0f0f0f (Manufacturer: 0x787, Part: 0xf0f0, Version: 0x3)
Info : JTAG Tap/device matched
Warn : no tcl port specified, using default port 6666
Warn : DBGACK set while target was in unknown state. Reset or initialize target.
target state: halted
target halted in ARM state due to breakpoint, current mode: Supervisor
cpsr: 0x600000d3 pc: 0x00100c28
Info : accepting 'gdb' connection from 0
Warn : srst pulls trst - can not reset into halted mode. Issuing halt after reset.
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x200000d3 pc: 0x001000bc
core state: ARM
force hard breakpoints
Info : dropped 'gdb' connection - error -400
Segmentation fault
