Hello Forum members,
I was hoping someone could help clarify for me the relationship between the Real values and the calibrated values for the Triad Spectroscopy Sensor AS7265. How do the calibrated values affect the real values? Any info on this would be helpful.
Thank you
It seems that those values are loaded into the calibration specific registers, so what those values actually do for the sensor is probably on the sensor side of things. You’ll probably have to ask AMS that question.
Thank you for the reply! Firstly, who is AMS.
Second, the real and calibrated values can both be adjusted by placing values after the input function, but still no clear relationship or impact on each other is clear.
Should one be used over the other or should both the get.calibrated and get.real functions be used together?
