SEN-18993
When I run the example sketch my sensor always reads about the same distance measurement no matter what. Seems to never go over 100mm. What could be the issue???
ESP-ROM:esp32s2-rc4-20191025
Build:Oct 25 2019
rst:0x1 (POWERON),boot:0x9 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3ffe6100,len:0x524
load:0x4004c000,len:0xa70
load:0x40050000,len:0x292c
SHA-256 comparison failed:
Calculated: 8dce998efc3eb6dc43f3799a489dbcfbd5ada9828beadf71017c05c4a8d32bc3
Expected: ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
Attempting to boot anyway…
entry 0x4004c18c
VL53L1X Qwiic Test
Sensor failed to begin. Please check wiring. Freezing…
Build:Oct 25 2019
rst:0x1 (POWERON),boot:0xb (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
entry 0x4004c18c
VL53L1X Qwiic Test
Sensor online!
Distance(mm): 89 Distance(ft): 0.29
Distance(mm): 86 Distance(ft): 0.28
Distance(mm): 83 Distance(ft): 0.27
Distance(mm): 69 Distance(ft): 0.23
Distance(mm): 76 Distance(ft): 0.25
Distance(mm): 65 Distance(ft): 0.21
Distance(mm): 72 Distance(ft): 0.24
Distance(mm): 99 Distance(ft): 0.32
Distance(mm): 78 Distance(ft): 0.26
Distance(mm): 93 Distance(ft): 0.31
Distance(mm): 70 Distance(ft): 0.23
Distance(mm): 74 Distance(ft): 0.24
Distance(mm): 79 Distance(ft): 0.26
Distance(mm): 77 Distance(ft): 0.25
Distance(mm): 73 Distance(ft): 0.24
Distance(mm): 68 Distance(ft): 0.22
Distance(mm): 75 Distance(ft): 0.25
Distance(mm): 85 Distance(ft): 0.28
Distance(mm): 64 Distance(ft): 0.21
Distance(mm): 141 Distance(ft): 0.46
Distance(mm): 71 Distance(ft): 0.23
Distance(mm): 80 Distance(ft): 0.26
Distance(mm): 98 Distance(ft): 0.32
Distance(mm): 81 Distance(ft): 0.27
Distance(mm): 97 Distance(ft): 0.32
Distance(mm): 58 Distance(ft): 0.19
Distance(mm): 44 Distance(ft): 0.14
Distance(mm): 45 Distance(ft): 0.15
Distance(mm): 42 Distance(ft): 0.14
Distance(mm): 38 Distance(ft): 0.12
Distance(mm): 35 Distance(ft): 0.11
Distance(mm): 40 Distance(ft): 0.13
Distance(mm): 46 Distance(ft): 0.15
Distance(mm): 82 Distance(ft): 0.27
Distance(mm): 84 Distance(ft): 0.28
Distance(mm): 94 Distance(ft): 0.31
Distance(mm): 88 Distance(ft): 0.29
Distance(mm): 90 Distance(ft): 0.30
Distance(mm): 96 Distance(ft): 0.31
Distance(mm): 92 Distance(ft): 0.30
Distance(mm): 100 Distance(ft): 0.33
Distance(mm): 87 Distance(ft): 0.29
Distance(mm): 95 Distance(ft): 0.31
Distance(mm): 91 Distance(ft): 0.30
Distance(mm): 125 Distance(ft): 0.41
Distance(mm): 109 Distance(ft): 0.36
Distance(mm): 51 Distance(ft): 0.17
Distance(mm): 22 Distance(ft): 0.07
Distance(mm): 24 Distance(ft): 0.08
Distance(mm): 23 Distance(ft): 0.08
Distance(mm): 26 Distance(ft): 0.09
Distance(mm): 25 Distance(ft): 0.08
Distance(mm): 27 Distance(ft): 0.09
Distance(mm): 61 Distance(ft): 0.20
Distance(mm): 62 Distance(ft): 0.20
Distance(mm): 107 Distance(ft): 0.35
Distance(mm): 144 Distance(ft): 0.47
Distance(mm): 134 Distance(ft): 0.44
Distance(mm): 154 Distance(ft): 0.51
Distance(mm): 179 Distance(ft): 0.59
Distance(mm): 205 Distance(ft): 0.67
Distance(mm): 228 Distance(ft): 0.75
Distance(mm): 248 Distance(ft): 0.81
Distance(mm): 265 Distance(ft): 0.87
Distance(mm): 273 Distance(ft): 0.90
Distance(mm): 246 Distance(ft): 0.81
Distance(mm): 209 Distance(ft): 0.69
Distance(mm): 164 Distance(ft): 0.54
Distance(mm): 118 Distance(ft): 0.39
Distance(mm): 148 Distance(ft): 0.49
Distance(mm): 188 Distance(ft): 0.62
Distance(mm): 227 Distance(ft): 0.74
Distance(mm): 263 Distance(ft): 0.86
Distance(mm): 287 Distance(ft): 0.94
Distance(mm): 295 Distance(ft): 0.97
Distance(mm): 296 Distance(ft): 0.97
Distance(mm): 291 Distance(ft): 0.95
Distance(mm): 279 Distance(ft): 0.92
Distance(mm): 272 Distance(ft): 0.89
Distance(mm): 262 Distance(ft): 0.86
Distance(mm): 260 Distance(ft): 0.85
Distance(mm): 258 Distance(ft): 0.85
Distance(mm): 261 Distance(ft): 0.86
Distance(mm): 266 Distance(ft): 0.87
Distance(mm): 259 Distance(ft): 0.85
Distance(mm): 277 Distance(ft): 0.91
Distance(mm): 271 Distance(ft): 0.89
Distance(mm): 238 Distance(ft): 0.78
Distance(mm): 172 Distance(ft): 0.56
Distance(mm): 159 Distance(ft): 0.52
Distance(mm): 162 Distance(ft): 0.53
Distance(mm): 167 Distance(ft): 0.55
Distance(mm): 161 Distance(ft): 0.53
Distance(mm): 145 Distance(ft): 0.48
Distance(mm): 137 Distance(ft): 0.45
Distance(mm): 112 Distance(ft): 0.37
Distance(mm): 111 Distance(ft): 0.36
Distance(mm): 119 Distance(ft): 0.39
Distance(mm): 121 Distance(ft): 0.40
Distance(mm): 115 Distance(ft): 0.38
Share a photo of your wiring/setup and the object being detected
You also might want t confirm the config mode using the functions listed here https://learn.sparkfun.com/tutorials/qw … y-overview
The wiring is the qwicc wiring… its a plug. And I am using the tutorial code from your site. The object is my hand or my table.
TS-Russell:
Found the issue.
