SEN-23880 hall sensor
Does anyone know if you can back bias the hall sensor particularly in the Z axis. There is an example in the Technical documentation that isn’t very good. I experimented on my own with a magnet and didn’t get any iron sensing result.
I have some generic advice that I found:
Magnet Placement
  1. Obtain a small, strong permanent magnet (e.g., a neodymium magnet).
  2. Position the magnet directly behind the TMAG5273 sensor chip, opposite the sensing side
    Datasheet (refer to this several times for specs, figures, etc). The magnet should be aligned with the Z-axis of the sensor.
  3. Ensure the magnet is fixed in a stationary position relative to the sensor…this creates the back-bias configuration.
Sensor Configuration
  1. Configure the TMAG5273 to use its Z-axis channel for sensing.
  2. Adjust the sensitivity range of the Z-axis channel to accommodate the magnetic field strength of your back-bias magnet. The TMAG5273 offers multiple sensitivity ranges
    (https://www.ti.com/lit/ds/symlink/tmag5273.pdf)
  3. Program the sensor’s settings, including the Z-axis configuration and sensitivity.
    The TMAG5273 has built-in offset cancellation features. You’ll need to configure these to work with your back bias setup:
    a. Use the Z_THR register (address 0x0F) to set the threshold for z-axis measurements.
    b. Adjust the CONV_AVG register (address 0x09) to set the number of samples for averaging, which can help stabilize readings with the back bias applied.
Calibrate
  1. Perform a brief calibration routine to measure peak output values from the Z-axis
  2. Calculate the offset to subtract from each measurement using the formula:
    Offset = (Outmax + Outmin) / 2
  3. Normalize the amplitude by dividing each output by the total amplitude
And that should get ya goin
