Sensor compatibility
Can you tell me if it is possible to use this sensor with the amplifier
https://www.sparkfun.com/products/13879
https://www.mesurtec.com/Downloads/fich … heet-e.pdf
Thanks for your help
Hi Tuonoman,
The [SparkFun Load Cell Amplifier should work with that load cell. The wires may not match the typical coloring that we list on the product page and [Hookup Guide so just double check the datasheet for that sensor to make sure you connect the load cell properly.](https://learn.sparkfun.com/tutorials/load-cell-amplifier-hx711-breakout-hookup-guide)](https://www.sparkfun.com/products/13879)
Dear TS-Mark,
thanks for your hanswer, We’re going to try.
Best regards
