Septentrio power source
Good day. I’ve been struggling with powering my mosaic-5s. I have 2 boards and a rfd900 radio. I finally was able to get rtk working when i hooked them all up to the same power source, a battery pack. I was able to use my windows tablet to power the board but when i plugged the charger into an inverter the board doesn’t work. I’m wondering if a 5 volt 9a voltage regulator would be a stable enough power source to run everything?
Yes, that should work…you could also use a ‘power bank’ that pushes at least 2a to the usb ports and power all of the items that way too (very portable)
Ok, thanks… I’ll try the regulator. It’s in a tractor most of the time, so ican have a wired power supply most of the time.
