Recently (in the past few days or so) I have had difficulty previewing and posting responses. I receive a message box saying that a Server Error has occurred and that the admin might not have enabled CGI for the folder. If I wait and try submitting enough times, the post/preview goes through. It sounds like a server availability issue.
Me too, except that I tried resubmitting a couple of times and still couldn’t submit. I eventually gave up and figured the admins would fix it later. (This was over the weekend.) I wonder if this post will make it through?
Its actually one of our new server security measures. Please email me a copy of the text its triggering on. One of the attack detection rules might be a bit overzealous.
Cheers,
–David Carne
Wow, that’s really annoying. ![]()
I didn’t save a copy of the text. It was a longish but innocuous response to the ethernet-serial-ethernet question in the “Projects” forum.
Yeah, sorry about that :/.
I’ll check the logs for the last few days for entries regarding the forum.
Cheers,
–David Carne
I know one time I was just using the QUOTE and it didn’t like something about that. I’ll pay more attention the next time this happens.
Thanks.
Yes, I’ve had this happen too, but after a refresh, it submitted fine.
I’ll be sure to copy down whatever I was writing next time it happens.
I’m glad that you guys are taking more precautions and preventing spammers and such now, the forum is a lot better, back to the way it used to be.
-Nate
I think I nailed the main rule that was causing issues. It was an overly excited SQL injection filter. Please let me know if you see any more unnecessary Internal Server Errors.
Cheers,
–David Carne
Hello!
I just got the “Internal Server Error” starting a new topic on the “Everything ARM and LPC” section.
I tried to submit several times, but I got the error each time.
I tried to send a Private Message to the Moderator of the forum, but same thing happened.
I have posted a couple of messages before, and I worked. This post reply was sent successfully. How can I start a new topic or send anything?
Alex
