New to Arduino - so please be patient.
I am working with a new Sparkfun Arduino One kit.
I am mashing up the servo example and the temperature example so that the servo would move (eg to open a cooling valve) when a certain temperature (24 deg) is exceeded.
When I run the sketch without the servo (the micro A0090) in the circuit all works fine.
(The servo script ran fine before adding the temp control BTW)
When I add the servo the temperature sensor (TMP36) gives high readings (like 20 deg C high, not a subtle interference).
I am sending the data to the serial monitor (am adding in comments here with //)
22.27 Temp OK - flow closed
22.75 Temp OK - flow closed
21.78 Temp OK - flow closed
22.27 Temp OK - flow closed //plug servo into board - servo cycles to closed
60.35 Temp high - flow open // way wrong temp - servo cycles to open position
33.50 Temp high - flow open // no servo change
24.22 Temp high - flow open // no servo change
23.73 Temp OK - flow closed //servo cycles to closed position
36.43 Temp high - flow open //note new artificially high temp servo cycles to open position
33.98 Temp high - flow open // etc. etc.
35.94 Temp high - flow open
35.45 Temp high - flow open
34.96 Temp high - flow open
21.78 Temp OK - flow closed //unplug servo
Code is as follows:
(yes - there is still some push button code in here i used to test setting the 2 positions of the servo)
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
// constants won’t change. They’re used here to
// set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
//TMP36 Pin Variables
int temperaturePin = 0; //the analog pin the TMP36′s Vout (sense) pin is connected to
//the resolution is 10 mV / degree centigrade
//(500 mV offset) to make negative temperatures an option
int pos = 0; // variable to store the servo position
int flow = 90; // valve at 0 allows flow
int inject = 0; // valve at 90 allows injection
int reps = 5; // number or repitions in demo
int topen = 5; // time open in seconds
int buttonState = 0; // variable for reading the pushbutton status
int templimit = 24; //Temperature limit to trigger action
void setup()
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.write(flow); // make sure we start allowing flow
pinMode(ledPin, OUTPUT); // initialize the LED pin as an output:
pinMode(buttonPin, INPUT); // initialize the pushbutton pin as an input
Serial.begin(9600); //Start the serial connection with the copmuter
//to view the result open the serial monitor
//last button beneath the file bar (looks like a box with an antenae)
Serial.print(templimit);
Serial.println(" templimit");
void loop() {
float temperature = getVoltage(temperaturePin); //getting the voltage reading from the temperature sensor
temperature = (temperature - 0.5) * 100; //converting from 10 mv per degree with 500 mV offset to degrees volatge less 500mV times 100
Serial.print(temperature); //printing the result
delay(1000); //waiting a second
if (temperature > templimit) {
digitalWrite(ledPin, HIGH); // turn LED on
Serial.println(" Temp high - flow open");
myservo.write(flow); // tell servo to go to position flow
delay(150); // waits 15ms for the servo to reach the position
else {
digitalWrite(ledPin, LOW); // turn LED off
Serial.println(" Temp OK - flow closed");
myservo.write(inject); // tell servo to go to inject position
// getVoltage() – returns the voltage on the analog input defined by
// pin
float getVoltage(int pin){
return (analogRead(pin) * .004882814); //converting from a 0 to 1023 digital range
// to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
I have not been able to find anyone else describing this kind of interference.
Thanks for help/ideas.
Joe
UPDATE: Bit of additional info. It looks like the servo is pulling the voltage on the board down to 3.7-3.9. I am willing to bet that is the cause. I will try this later with a better power supply, but all insights are appreciated.
