Setting up the Logomatic as the Ulitmate IMU
Guys,
Greeting…would you be interested in helping me with a Logomatic project?
I need to setup the Logomatic as the Ultimate IMU.
I have spend some time with Ryan Owens code for the Ulitmate IMU and I think I can make it work on the Logomatic.
Would I be better off modifing the code or the hardware?
As you know, Sparkfun used the I2C lines for a stop switch and status led on the Logomatic.
How could I modify Ryans code to just use any GPIO pins as SCL and SDA?
Thank you for your time,
MAKeller
