So apparently the below being all 0xFF means that the SPI isn’t working:
Display Power Mode: 0xFF
MADCTL Mode: 0xFF
Pixel Format: 0xFF
Image Format: 0xFF
Self Diagnostic: 0xFF
Some boards you have to do some soldering - I hope that isn’t the case with this board. I have been looking at the board schematics and trying any pin that looks like it might work. I get the above when I use the pins labeled DISP_CS, DISP_D/C and DISP_RST; which are 10, 18 and 44, respectively. Otherwise I get 0x0 for everything and the test hangs.
