Hi, I am having a problem communicating Si7021 T/H sensor with the NRF52832 Breakout Board.
I’ve done step-by-step through the hook-up guide according to (https://learn.sparkfun.com/tutorials/nr … -guide/all) and (https://learn.sparkfun.com/tutorials/si … -guide/all) but the Serial Monitor appears no reading. When I disconnect the sensor, the Serial Monitor shows the following reading.
https://i.imgur.com/gRzjLY4.png
Once I connected the sensor back to the I2C line, the Serial Monitor freeze, stop showing data unless I disconnect the SDA line from the sensor.
I hooked up a logic analyzer and found out that the Master(NRF52832) performs correctly when not connected to the sensor,
https://i.imgur.com/4bSPR7v.png https://i.imgur.com/WeypuRJ.pngWhen connected to the sensor, the logic always shows high.
https://i.imgur.com/P8ui4dZ.pngI’ve changed the pinout for I2C in variant.h()
#define PIN_WIRE_SDA (15)
#define PIN_WIRE_SCL (14)
When I hook up my sensor to Arduino nano, everything work just fine.
https://i.imgur.com/c3gNi78.pngI use the S132 soft device on the NRF52832.
I think there is something wrong with the sensor.begin or wire.begin function using on nrf52832 board but I can’t find the cause.
