Could someone help a noob?
Could someone please tell me what a “breakout” board is in VERY basic terms. I am soooo new to all of this.
Mike
Mike
It’'s a PCB for a fine pitch device that brings the leads out to wider pads, making it easy to wire it into a circuit.
okay, so, (knowledge check) it is a board that will attach to a “main” board, that does a certin task, that is larger-and easy to work on.
A) True
B) False
C) All of the above… lol, just kidding
Thanks for the help!
Mike
D) Not sure what you mean
Things in this category are breakout boards:
To combine all the above: Breakout boards often describe one of two things
Adapters to convert either connectors or ICs to a convenient footprint. This includes ones that go from a fine-pitch LCD connector to 0.1" headers, and boards with hard-to-mount parts (tiny surface mount parts, BGA or QFN footprints) and a header or connector. They often include other components that are always needed or have to be close to the part (bypass caps, pullup resistors, crystals). http://www.sparkfun.com/products/9614 and http://www.sparkfun.com/products/9719 are examples of this type
Modules that encapsulate functionality, like a complete MP3 decoder/audio amp or USB to serial interface, that can be used as part of a larger project. http://www.sparkfun.com/products/10277 and http://www.sparkfun.com/products/718 are examples of this type
/mike
