Simple BLE data trasfer example between two Artemis modules
Looking for a simple data transfer example to demonstrate transfer of data (eg sensor data) between two Artemis modules (eg between Artemis Redboards). I started looking at the examples in the apollo3_evb folder of AmbiqSuite and found these:
ble_freertos_amdtps “ARM Cordio BLE - AMDTP Server (Slave) Example.”
ble_freertos_amdtpc “ARM Cordio BLE - AMDTP Client (Master) Example.”
Are these good starting points and has anyone had success bringing these into the Arduino IDE environment?
Just a tutorial on how to port examples from one tool chain (eg AmbiqSuite) into Ardino would be useful.
It would be great if eventally, more BLE examples based in the Arduino environment were available. This would surely increase the popularity of Artemis based hardware.
Update: just received the following notice from sparkfun support (thru similar email support request):
“We would be happy to research your question and if possible, answer it in the forums. That way, if other users have the same question they and the rest of the community can benefit from your post, and anyone else in the community that has solutions for you can post them as well.”
While this sounds promising I was hopng for something a little more concrete. For now, I will exclude this board from consideration as there has been no indication whther a Arduino BLE library for Artemis is in the works or when it may arrive. Instead I will focus on another vendor’s board that already has a working BLE library for Arduino.
