Simple Photoresistor Lighting (Self Tutorial)
I am new to Arduino.
I want to teach myself how to use it.
So, I want to setup 4 multi-color leds and have them react to data from 1-2 photo-sensors, (I would say photoresistors, but I don’t know what is best.)
What Arduino model should I get, and what kind of kit should I be grabbing.
I have a working knowledge of non-digital circuitry.
Please help. I’m a designer.
Designer of what?
Is the end result intended to go into some permanent “art” installation ? To be powered how ? Is there some packaging or size constraint ? Do you envision doing more Arduino related projects ?
I ask because some boards are easy to get started with but are larger and more $$s than other boards. Four RGB LEDs would use almost all the I/O pins on an Uno, leaving not much for switches, etc. Your 2 sensors would go into the analog pins. So a basic Uno might work but a smaller “pro” might be a better fit in a permanent installation. You’ll need some other stuff but I’d need to know more about the project.
