Never tried, but in order to read/write on a specific address with a specific length, I have modified the original Sparkfun library before. There is a call and example to handle that for user bank/Tid bank. Take the latest version from https://github.com/paulvha/ThingMagic/t … ib_special.
However, to keep the RFID signal on for 2.5mS, the full MercuryAPI (Linux or Windows) has an option :/reader/gen2/writeReplyTimeout which is not in the scaled-down version of Sparkfun. But you can still try and see what happens.
I’ll try with your library but I was already able to read specific addres from one of the four banks
The problems is that, for the documentation of this Rfid sensor, I need to send a “standard SELECT command” to an addres of the bank 3 and then a “standard READ command” to an addres of the bank 0: if I try to use the read command also for the first part I don’t have the correct answer from the sensor
p.s. Just few minutes ago I found more comments from others who have attempted the acquisition and they said there is no this possibilities with the Sparkfun Rfid Tag Reader…
