I’m looking for a SIRFStar IV module that doesn’t come with an antenna attached. Where can I get a high performance one with 66+ channels etc. ?
All CSR GSD4e (SiRFStar 4) are marked as 48 channels:
http://www.csr.com/products/35/sirfstariv-gsd4e
And nobody would ever need more than that as GPS has only 37 allocated PRN IDs ![]()
You may look here:
http://michelebavaro.blogspot.com/2011/ … rrier.html
for a non-exhaustive list of antenna-less modules; depending where you live, some may be easier to buy than others.
Cheers,
Michele
Thanks, Michele.
Do you know if breakout boards are available for any of those modules? I wasn’t able to find any.
Hi Anon,
The main issues when evaluating GSD4e-based modules are:
I/Os are usually CMOS 1.8V
you need to generate a 100ms pulse to turn them on/off
But still, there a few eval kits out there:
http://uk.rs-online.com/web/p/gps-globa … m/0537717/
http://uk.rs-online.com/web/p/communication/7165299/
http://uk.mouser.com/ProductDetail/Maes … zslb7Bo%3d
http://uk.mouser.com/ProductDetail/Wi2W … mcKtvyY%3d
etc…
Is that what you were looking for? A simple breakout would have little value as these modules are fairly easy to solder to your PCB using slightly extended copper pads.
Best regards,
Michele
