Hi there,
I need to know the size of the following types under AT89S8253 (an 8051 derivative):
sizeof(short) = ?
sizeof(unsigned long) = ?
sizeof(float) = ?
Best regards
Hi there,
sizeof(short) = ?
sizeof(float) = ?
Best regards
As with the AVR chip that you asked about on another forum, this too is an 8 bit micro, and the question goes to the choice of compiler and compiler configuration options, not the chip.
Is this a homework assignment?
Compile this code for your target and run it:
#include <stdio.h>
int main(void)
printf("sizeof(short)=%d\n", sizeof(short));
printf("sizeof(unsigned long)=%d\n", sizeof(unsigned long));
printf("sizeof(float)=%d\n", sizeof(float));
while (1);
return 0;
Thank you very much for the answer - I compiled a program that finds out the sizes of these types - it worked for me.
I am using Keil uVision IDE.
Yes, it is like a homework assignment ![]()
