Hi
Just got Redboard Artemis ATP, and using it with Arduino IDE. I found the compile speed is really slow.
To compile and upload the blink sample took more than 10 seconds, is this normal?
Is there a way to improve this?
Hi
Are you on a PC? The IDE is written in Java, and on my PC (16-Core AMD Threadripper) it still takes a while to start up and also to compile - even my Lightroom/Photoshop application is faster.
Thank you for the response.
I understand the IDE is Java, but C compiler should not be that slow, is the IDE doing some unnecessary work behind?
Is the upcoming new IDE (using CLI behind) speed up this process?
If you turn on verbose output (file->Preferences, set both verbose compile and upload) you can see what is happening under the covers. I’ve downloaded the Beta IDE and haven’t noticed a difference in speed, but I mainly use Visual Studio with the Visual Micro extension for development work.
It will be faster the second time you compile, as the first time around, the entire Arduino core has to be compiled and cached.
A 10 second wait does not seem all that onerous to me.
Thank you! now I am trying to do this using SDK. still got one issue, but should be much faster.
Are you using v2.x of the Apollo3 Core? I’ve found that compiling times are significantly slower with v2.x compared to v1.x in the Arduino IDE. Mbed OS really seems to make things sluggish.
Hi adam.g
Yes, you’re right, with v2.0.6
