So i got my board back from batch..
Everything looks agood. I got everything solder. My voltage regulator works, woot i did 1 thing right.
Problem is when i put it on the arduino i get horrible results just seems flaky as crap i dont seem to be getting good connection from any of the pins plugged into the arduino.
Maybe because i used round pins instead of square?
Would anybody be interested in taking a look at this for $30. i would be happy to pay to have it shipped both ways.
Erm, all i can guess is that you’ve made a shield but thats about it… :lol:
Kinda need to know what you want to achieve and what components you have, if you
want to post a few images of you’re schematics and boards or even better Eagle files
(if you’re using that) that would be good for debugging…
There really is no debugging electrically everything is fine. It just fits together like crap. My soldering could suck as well.
Yes its a shield. it basically has a switch, that has 3 outputs to optocouplers that then switch 3 12v relays.
FartingMonkey92:
Erm, all i can guess is that you’ve made a shield but thats about it.
[[Read this thread by the OP](http://tinyurl.com/57kelq).
From it I concluded that this project
has a lot in common with the [Titanic…](Titanic - Wikipedia)](http://tinyurl.com/57kelq)
What pins? What connector? Part numbers? Datasheets? Pictures? Anything?
