rpcelectronics:
I am storing it in the fridge now and it seems to be just fine.
The solder paste will deteriorate over time, the 'fridge
slows the process. In theory the paste will only last
six months from manufacture according to the vendor.
I’m currently using [Kester R276 solder paste.
rpcelectronics:
Since I did not have any kind of syringe to dispense the paste with, I went with my trusty X-acto handle and straight pin with the plastic head cut off (this makes a nice pick for general PCB work).
When you get a syringe and needle you will find "dotting"
pads much easier. If in doubt put less solder paste
down, it saves a lot of time on rework.
rpcelectronics:
All in all, I am very pleased with the results and I think I am going to give this a go on my next batch assembly.
Let the paste reach room temp each session.
Store unused paste back in the 'fridge.
Although the given shelf life is six months. I have
been using the same tube for two years (!)
No doubt it is less ‘fluid’ but solders up fine.
At first I used 26Ga needles and hand pressure,
now I have changed to 18GA needles, yet
it requires quite a bit of force to squeeze out
by hand. As a plunger I found a plastic highlighter
pen to be a good substitute. (I should have ordered
a plunger with the syringe…).
I was removing the needles each session
and poking out the needle with a wire. Now I just
leave the needle on and don’t bother to cap it.
It really helps to keep air out of the paste, the
manufacturers go to a lot of effort to have 'void-
free’ paste in the syringe.
An air driven dispenser with foot switch would be
a much better arrangement (as I don’t have
compressed air or nitrogen in my home lab, this
project is on my back burner, indefinitely).
Good luck! You’ll wonder how you got along without
paste solder for SMT assembly.](http://tinyurl.com/5ed964)
