Monday, BatchPCB shipped my boards. Since I knew I wouldn’t get the stuff I ordered from DealExtreme before I got the cards, I ordered the solder paste, syringe, and needle kit from Jameco as suggested in this thread. (Thanks!)
Received the pcbs today. But,when I tried picking up and placing those tiny SuperSOT6 parts with the tweezers, it was OMG! What was I thinking! This is impossible!!
It was a mess. Just grabbing the parts with the right side up was the first adventure. Then, the parts would always stick to the tweezers. I resorted to just getting them close, then pushing them into place with a pointy tool I have.
Ended up dragging parts through paste and making what looked like a total mess. But I said, WTH, I’ll try reflowing on the hot plate to see which parts reflow ok, so I could guage how much better I needed to get.
It was a thing of beauty! Watching that ugly gray mess turn shiny and the parts magically align was awesome! I never dreamed the solder dispensing could be so sloppy and the result still turn out well.
One of the SOT6 did skew badly, so badly the pins got soldered to the wrong pads. So, I removed it, use braid to clean the pcb and part pads, then soldered manually (wicking the bridged leads with braid).
Haven’t functionally tested the board yet, but I did beep out all the fine pitch leads and verified connections to the card and no shorts to adjacent component leads.
Anyway, this is probably “old hat” for most of you, but it was quite exciting for a newbie (at DIY pcb reflow)! Kudos to SparkFun for their great tutorials and other trememdous resources!
Finally, the question. Is it ok to reflow the card more than once? As an example, to straighten out the bad SOT6 while the solder was in the liquid state? Or is reflowing multiple times a bad idea?
Dave Thomas
