Hey guys, I’m working on a project which includes building a clock that will play 12 different music files (probably 5 seconds each). Is there a good micro controller that can handle storing the music files and playing each file when it receives a voltage signal from a clock movement. This is the same as what a bird clock would do, only the sounds would be different.
You could add this module to any microcontroller
https://www.sparkfun.com/products/11125
Read the reviews in above reference, e.g this link
Thanks for the response. I’m looking for a way to store the music files onto the microchip and play it back when it receives a signal. Is there a type of chip that can do this with decent sound quality.
The ISD ChipCorder series may meet your needs.
A rough order of magnitude (ROM) of a 4 KHz signal sampled would be (4k x 2 Nyquist x 12 files x 5 sec) or 480KB (assuming 8 bit DAC) before compression so you will likely need a MCU card that has an SD card port. A 4 Khz 8 bit signal is decidedly Lo-Fi so scale appropriately. If you are looking for a single board MCU this might be a place to start:
https://www.pjrc.com/teensy/td_libs_Audio.html (Teensy MCU), you will still need to drive your speakers with something like this which mates to the Teensy (see link for photos): https://www.pjrc.com/store/teensy3_audio.html
