Sound detector with Raspberry Pi
Hello everybody !
This is my first post on this forum so tell me if I do something wrong and sorry for my english, i’m french.
I want to mesure the decibel level in a room with a Raspberry 3B so I bought the SparkFun Sound Detector.
So I have the SparkFun’s sound detector and I have a MPC3008 (ADC) because I need to read the “envelope” output of the detector that is an analog output and a Raspberry don’t have analog input.
I plugged everything well and I’m able to read the output value that give me the MP3008 :
Raw ADC Value: 2048
ADC Voltage: 0.20625314717326618V
But my problem is the following : how to convert this value in dB ?
I saw some solutions and formulas for arduino but that don’t work in my situation.
Can someone help me with this ?
Thank you !
Have you tried this library by the way?
https://github.com/swapnilbembde/Sound_Level_Meter
Thank you for your answer. It seems to be hard for me to try. No details privded on what sensor he used, connectors, adc, output …
A single ADC measurement can’t be converted into dB units. You need to average some measurements over a period of time (usually root mean square), possibly using some weighting factor.
The dB measurement is computed from the logarithm of the ratio of the current average to a reference average.
The easiest way to calibrate your microphone is to compare the logarithm of the averaged output to the reading of a professional sound level meter, in a variety of noisy environments.
