SparkFun Battery Babysitter - LiPo Battery Manager Libray
I have purchased the SparkFun Battery Babysitter - LiPo Battery Manager and started using the library provided for Arduino (https://github.com/sparkfun/SparkFun_BQ … no_Library). How can I read the data of the R_a RAM subclass (Page 48 of the reference manual attached)? If I need to modify the library can I get suggestions on how can I do it?
Thanks a lot,
Mun
Which reference manual are you referring to? One of the datasheets available for that product is only 29 pages long, and the other has packaging information on page 48. Can you link to your referenced datasheet? There is a small bug at the moment with attaching photos and other files to forum posts.
TS-Brandon:
Hello Brandon,
I am attaching the reference manual here again. I am not sure if you can see it now. Just in case I’m adding the link of the reference manual also
https://www.ti.com/lit/ug/sluuac9a/sluu … e.com%252F
My question again:
how can I read all the 15 values of Ra table mentioned on page 48? Sparkfun has a library (https://github.com/sparkfun/SparkFun_BQ … no_Library) but it doesn’t read the Ra values. How should I modify the library?
Thanks for your time!
That is beyond the scope of our technical support staff. We can not support custom code or code alterations.
