I’m using the sparkfun DRC for the layout on my board and it reports clearance errors for the space between the pads on the ATMega328 device I imported after exporting the official Arduino Uno SMD eagle part, as well as the level converter chip I’m using. What can I do on the clearance tab to eliminate this problem? I tried changing to 6mil pad to pad on the DRC clearance tab but it gives me an inconsistency error.
I’ve attached an image to illustrate the error. Hopefully attachments are working again…
