Hi John,
A couple of thing to check:
Connect the board to your PC via USB and open up u-center.
Select the correct COM port and connect to the module.
You should see the satellite signal strength ‘bar chart’ etc. appear?
Open View \ Messages View
Use the message ‘tree’ to select UBX-CFG-PRT
Select 1-UART1 as the Target
Click Poll at the bottom of the window
Check that you see UBX in both Protocol-In and Protocol-Out
By default, it should be UBX+NMEA+RTCM3
If not, select UBX+NMEA+RTCM3 for both In and Out and click Send at the bottom of the window
No UBX messages are output by default. You need to enable them. I assume the PixHawk does this - but maybe not?
Select UBX-CFG-MSG in the tree
Select (e.g.) 01-07 NAV-PVT
Tick UART1. Leave the rate box set to “1”
Click Send at the bottom of the window
The NAV-PVT (Position Velocity Time) message should now be being output on UART1 once per second.
If you enable it on USB too and then select UBX-NAV-PVT in the tree, you should see the fix details being updated every second?
You will also see the UBX data in View \ Packet Console or View \ Binary Console
You can reset the module back to the factory defaults with UBX-CFG-CFG
Select “Revert to default configuration” and click Send
Then click “Save current configuration” and click Send
You can check what software your module is running with UBX-MON-VER
Upgrade instructions are here:
https://learn.sparkfun.com/tutorials/ho … 1583443041
Let us know how you get on,
