SparkFun GPS-RTK-SMA Breakout - ZED-F9P GNSS Antenna specs
I´ve got an 16481 SparkFun GPS-RTK-SMA Breakout - ZED-F9P (Qwiic) and I would like to know which GNSS antenna specs should I consider to use with.
I would like to know if an Hemisphere A42 antenna is compatible with the 16481 SparkFun module.
Thanks a lot for your help
Yep! It’s triband, 3-12V input, and 35mA typical. Should work great!
