I’m trying to combine a MicroSD program with a WIFI server program.
The WIFI server program is one I found online and works perfectly. I can login to
the RedBoard and toggle the blue LED with my phone.
When I add in the standard SD program I can no longer toggle the LED.
I’ve removed all the SD software except for sd.begin(5, SD_SCK_MHZ(32));
If I comment out sd.begin the wifi program works.
Either there is a hardware conflict using both at the same time or the one processor can’t handle both tasks
If its a software problem do you think moving the wifi program to the second core would fix the problem?
If its a hardware problem what could be causing it?
